Pomoc přepytać
Hladajće so wobšudstwa pomocy. Njenamołwimy was ženje, telefonowe čisło zawołać, SMS pósłać abo wosobinske informacije přeradźić. Prošu zdźělće podhladnu aktiwitu z pomocu nastajenja „Znjewužiwanje zdźělić“.
Dalše informacije
Rotate screen erroe
  • 2 wotmołwje
  • 4 maja tutón problem
  • 2 napohladaj
  • Poslednja wotmołwa wot Paul
As I try to rotate the screen orientation while using Firefox Focus, the screen goes blank. This doesn't happen elsewhere on any other app on my device. I tried re-installing and restarting my phone, but I have the same problem. Anybody encounter this issue?
Wšě wotmołwy (2)
Hi
This is some that our developers are aware of and are looking into. You can follow progress on this and add comments at:
https://bugzilla.mozilla.org/show_bug.cgi?id=1812114
Hi
I understand that this has been resolved in Firefox Focus for Android version 109.2. Please look out for an update from the Google Play store.
I hope that this helps.
